show ip-security arp gratuitous-protection
Description
If configured for gratuitous ARP, displays the gratuitous ARP protection configuration on the switch.
Syntax Description
Default
N/A.
Usage Guidelines
The switch displays the name of each VLAN configured for gratuitous ARP.
If you do not have gratuitous ARP configured, the switch does not display any VLAN information.
The following command displays the gratuitous ARP configuration on the switch:
show ip-security arp gratuitous-protectection
The following is sample output from this command:
Gratuitous ARP Protection enabled on following VLANs:
Default, test
This command was first available in ExtremeXOS 11.6.
Platform Availability
